Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:57 pm)
How did you find out about the problem? If someone with a mac is telling you there is a problem ask them if the centerpoints for the clothing bodyparts are still the same in Poser as the for the figures body parts. This is easy to check in the joint editor window. They should be the same numbers and the crosshairs should line up the same. I'm no expert but in some modeling packages the numbers will be the same but the actual points do not line up because the coordinate systems are local and they are offset or scaled differently.
re the last comment, I just started with Poser 4.03 and noticed that Poser don't support the software with OSX in Classic mode, however apart from some problems with magnets I find that it is more stable in OSX than 9.2 (my Wacom tablet also works better with Poser in OSX so a further incentive to use X. It's such a hasle closing one system and starting another. About hair - I often find hair floating above the head of the model but then I'm using Millenium Girls and adult hair doesn't match. Brian
Jim... I'm using Poser with OSX.2 Jaguar. Poser runs in Classic... which means Poser hasn't been optimised for OSX. I tried the shirts also in OS9.2. Neither one worked properly. Your first beta pak the shirts worked fine... it's just when you posted the final ones that they stopped working. Whatever you did between those two versions may be the clue to the problem. Meantime I'll go check the joint editor window per scorer's suggestion.
I've got my fetishwear package 2 in beta, and most everything seems to be going fine (other than a coupld of minor problems. However, I do have one big headache I need help with. The tops I've done don't conform properly on Mac machines, they float above the figures head. They work fine on Windows machines. The shorts and pants I've done all conform properly on all platforms. I don't have a Mac to work out the problem on, and I need some kind of lead to try. Any ideas? Thanks! Jim
