Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Do you have a transmap applied? Without that, the eyelashes wil never look right.
You can usually use different transparency maps between Victoria characters, but you can not swap between Victoria and Mike. Some Victoria textures paint the eyebrows on the texture itself and make the real, external eyebrows completely transparent. Other texture maps use the eyebrow materials. You'll get funky results if you mix and match those. The eyelash transparencies will work seamlessly between different Victoria textures. Mike textures only work on Mike. Even Stephanie's eyelashes textures don't quite work properly with Mike or anyone else, as the mapping is just slightly different there. (Steph and Mike share the same basic mesh.) Hope this is clear, Cres
