Tue, Feb 18, 12:26 AM CST
Subject: Rochr: how do you make those light beams in the following pics?
pmoores ( ) posted Fri, 14 February 2003 at 10:56 AM · edited Sun, 02 February 2025 at 12:27 PM
Course anyone can hazard to point me to the right technique. Might want something similiar for my latest one as i approach the finish. Specifically its just the single light haze texture. Would it be a light with a faint light gel or a separate cone with a faint transparent layer. My issue is im planning to have a monster/cyborg peering around a corner but need to light it bright, while rest of scene much darker. http://www.renderosity.com/viewed.ez?galleryid=261554&Start=1&Artist=Rochr&ByArtist=Yes http://www.renderosity.com/viewed.ez?galleryid=326431&Start=1&Artist=Rochr&ByArtist=Yes
madmax_br5 ( ) posted Fri, 14 February 2003 at 3:46 PM
I am fairly sure he uses universe image creator for those fx.
Rochr ( ) posted Fri, 14 February 2003 at 5:19 PM
The sunrays are made per post! I personally have more control over it that way, and it also saves some rendertime. I usually use several beams, some wider as a base, and some thinner ones, pointed towards areas, that have reflections. Also, i overlap some beams and play around with the opacity. Just remember to use colors that maches the lighting in the scene, it usually gives the best result. Universe, i only use for flares and to enhance reflections. Heres the basic shape i use for the beams. Just add some softness, and linear opacity. Hope this helps! :)
Rudolf Herczog
Digital Artist
www.rochr.com
Rochr ( ) posted Fri, 14 February 2003 at 5:23 PM
...while im at it, heres a tip on those enhanced reflections! Its the same technique ive used on the "Outcast" character. You can see small flares on the hoses on its head, the feet etc. Its done in Universe Image Creator!
Rudolf Herczog
Digital Artist
www.rochr.com
pmoores ( ) posted Fri, 14 February 2003 at 9:48 PM
I see. Thanks... might have a use for highlighting and bringing out the main monster in the next one.
EYECON ( ) posted Sun, 27 April 2003 at 5:49 PM
Thank you very much Rochr for this comprehensive tute... i also try my best to find out ways to create scenes on bryce and polishing it up with photoshop... with this additional knowledge, i could improve more of my art... tnx!
