Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 6:38 pm)
"Hither" sets the point at which anything closer to the camera is invisible. To see it in action sight the camera up an arm from the finger tip and move toward the fingertip slowly. At some point, the tip will disappear and you will see "inside" the finger. Reduce Hither, and the fingertip will reappear. Technically, you could do the camera from the head's POV by putting the camera behind the head and then setting Hither to make the entire head invisible. That would have parallax problems with objects close to the head, though.
You can't use the cameras that switch from character to character, so forget Face, Hands, Posing, or Dolly. (Think about it. What happens when you switch current figure?) Your choices are Main or Aux, and that's about it. I did the whole thing with Aux, and when I move Mick's head, the camera moves to look at what he's looking at. I even animated it. No problem. (Well, except that her hair started hopping around, but that's another thread....)
Does anyone know how to parent a camera to the inside of a character's head, so I can look out "from their viewpoint?" I realize I would need to set the hither properly, but every time I try to parent the camera, it gets moved out from 'inside' the character's head. THanks,
