Tue, Feb 18, 12:31 AM CST
Forum Moderators: RedPhantom
Subject: Problem with PNGs in Poser Pro Pack
seaayre ( ) posted Tue, 06 May 2003 at 2:00 PM ยท edited Mon, 17 February 2025 at 10:58 PM
I just upgraded from Poser 4 to Pro Pack, and notice that some of my library files don't have an image anymore. Just a blank circle in place of an image. I checked, and there are PNGs in these files. Why won't they display? ::puzzled::
Crescent ( ) posted Tue, 06 May 2003 at 2:10 PM
Some .png files don't display quite right in Poser. If you use yarp's P3D0 Explorer and the .png<->.rsr converter plug in, you can fix them up.
iamonk ( ) posted Tue, 06 May 2003 at 4:05 PM
This problem has been asked before, so a search for PNG will most likely give you more help. Basically...if a PNG doesn't have any transparency info, Poser gets confused. Here's a quick fix if you use Paint Shop Pro, other apps should be similar... #1 Open the PNG in PSP #2 The picture is considered a "background" at the moment, you want to "convert to layer". #3 Choose the eraser and erase one pixal, whichever one you like(I prefer a corner) #4 Save That is all.
seaayre ( ) posted Tue, 06 May 2003 at 4:25 PM
Hmm. P3D0 didn't work, but erasing the pixel did. :) Thank you for the responses!
iamonk ( ) posted Tue, 06 May 2003 at 4:46 PM
No problem, this is the simplest fix I found.
Spit ( ) posted Tue, 06 May 2003 at 7:34 PM
If you use Photo-paint, open the .png, CTRL-A to select all, then resave.
yggdrasil ( ) posted Thu, 08 May 2003 at 11:51 AM
And for PhotoShop, open .png double click layer, OK, save.
Mark
