Tue, Feb 4, 9:48 AM CST
Subject: when i select a body or hed morph to inject for vic3
zvizka ( ) posted Tue, 06 May 2003 at 5:18 PM ยท edited Tue, 04 February 2025 at 7:14 AM
nothing happens Y plz help me
Lyrra ( ) posted Tue, 06 May 2003 at 7:59 PM
Do you have the Body Morph and Head Morph packages from DAZ installed? Did you move any files? Do you have the updating V3 base figure from DAZ? And have you emailed them? Their technical support is excellent.
grunthor ( ) posted Wed, 07 May 2003 at 5:28 AM
I had some problems with this at first too. Mostly because I didn't understand what I needed to do to make it work. First make sure you have the Morph pack for whatever body part you're trying to change. There are separate morph packages for V3 head and V3 Body. Select the morph you want to inject. When you do that a bunch of dials will appear that pertain to that morph. Normally they are set to ZERO as default. That's why when you inject the morph it doesn't do anything. Dial in a value on the wheels for whatever you want to do. this will determine how much morphing will happen. Finally click the checkmark to inject the morph into your figure.
