I had some problems with this at first too. Mostly because I didn't understand what I needed to do to make it work. First make sure you have the Morph pack for whatever body part you're trying to change. There are separate morph packages for V3 head and V3 Body. Select the morph you want to inject. When you do that a bunch of dials will appear that pertain to that morph. Normally they are set to ZERO as default. That's why when you inject the morph it doesn't do anything. Dial in a value on the wheels for whatever you want to do. this will determine how much morphing will happen. Finally click the checkmark to inject the morph into your figure.
nothing happens Y plz help me
