Tue, Jan 28, 6:21 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Tech Chalenge... Nostrals
momodot ( ) posted Sun, 04 June 2000 at 8:55 PM ยท edited Tue, 28 January 2025 at 6:02 PM
A simple fix for the glowing nostrals... I've tried transparent props in the nose but couldn't make it work.
jrsamples ( ) posted Sun, 04 June 2000 at 9:06 PM
Bloodsong has a fix for this. It gives the nostrils a material. It is at PoserWorld. It's Here: http://www.poserworld.com/textures8.htm
Geekholder ( ) posted Mon, 05 June 2000 at 12:46 AM
I generally select all of the polygons inside the nostril with the grouping tool, assign a new material to them, and darken the material significantly from the regular skin tone. A close up shot looking up into the nostril still doesn't look right, but from most other angles it looks fine.
polartech ( ) posted Mon, 05 June 2000 at 12:59 AM
If you have Photoshop (and this can most likely be done in other apps too), select the "glowing" bits with a small feather value, and drag down the Lightness value somewhat, until you get a match with the rest of the skin tones.
