Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
You're doing great. Aside from your observations, I have two. Put the painting closer to the wall... the shadow is too large. And change the trees, the look very similar as in very close to mirror images. Maybe a Bible on the desk with some paper and a quill pen in a modern type ink well. A trash basket on the side of the desk with crumpled paper in it. (lattices) Curtains are easy enough to do if you have a modeler. If not, go to your terrain editor, select one of the rolling hills fractals that seems to be lined up evenly (or use PTE if you have a P.C.) Then stretch the terrain long and taper the bottom end.
Its looking like a good solid start so far. Maybe move the light a bit further away form the wall to shrink the extent of the shadow from the painting. Also, a bit of work on the window sills and framing that holds the window to the house walls would make that part looks a lot better. Could also add a skirting board around the wall/floor join, but that may be what you call a baseboard.
Digital
WasteLanD
This is a great start! I agree about changing the camera angle. I think if it's pulled into the scene a little more, it will make the viewer feel as if he's actually in the room. I tried making curtains using the terrain editor once. They didn't turn out as nicely as the example shown above, but if I can do it, anyone can ;) How about a potted plant? A comfy chair and some throw pillows? When can I move in? heh heh
I mean the wooden window framing that covers the sides of the bricks (if you live in a brick house) that you'd see in the hole that the window is put in. Umm, the framing that is attached to the house that a slide window would slide up down in.... I'll try and find a pic for ya - think that'll be the easiest.
Digital
WasteLanD
And now, the list. :-) Increase the scale of the floorboards, so they are smaller. Increase the scale of the board grain texture on the desk, so it's also smaller. Chair, possibly, too, but I cannot see the grain properly. for the ceiling, use pure white with a smooth plaster texture for bump. (Take care of the scale.) There are appropriate textures on animax.it and mayang.com. The wallpaper looks pretty good, but you should possibly decrease the Ambience value. Ditto for the rest of the textures. Pull the camera closer to the desk. Or not, depends on what will be in the rest of the room. For the light, try creating a small light globe, five or six of them in a spherical form and very close to each other, with a very small light value. You'll get softer shadows. Another light (lamp) on the desk would be good. You might also put a darker texture on the sky, so there's a reason why the lights are burning. For curtains, IIRC, www.baument.com has a set of curtains in 3ds format. HTH.
-- erlik
Digital
WasteLanD
Minor thing.....we call them 'skirting boards'. They are pieces of wood that are fitted to walls to make a nice join with the floor...........almost everyone forgets them.
I think cornices are optional. We don't usually have them over here or picture rails. Certainly not in new houses.
I have both in my apartment (crown mouldings and plate or picture rail). They seem to be a feature of older (pre-50's) style buildings. Newer places are lacking such or have very much abbrevited versions. At least for Montreal, that is.
Attached Link: http://www.annsartgallery.com/fp.html
And, don't forget, for a relatively CHEAP price tag you can get IMSI floor plan. www.floorplan.comThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
