Fri, Nov 15, 8:23 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: 3D Boolean Operation WIN98 vs WIN NT
nemisis ( ) posted Sun, 04 June 2000 at 4:08 PM · edited Fri, 15 November 2024 at 6:45 AM
Alright, here's my dilema, I am presently using Win98 for Carrara. When attempting a 3D Boolean subtraction/insertion/ union or other operation I will get a rendering failure with "A C++ runtime Error...invalid page fault...." message. I would like to know 2 things: a) Does Carrara run better and less buggy in WIN NT (ie should I get WIN NT); and b) Does anyone know of a workaround for the above rendering failure?
pem ( ) posted Sun, 04 June 2000 at 11:59 PM
Antoine has previously posted that Carrara runs better on NT and 2000: ie. more stable and handles memory better. I am afraid I have no other workaround except if you upgraded from RDS, try it in RDS and then import into Carrara. Your problem sounds like a memory management problem.
Shroud ( ) posted Tue, 06 June 2000 at 12:53 AM
WinNT has better memory management than 98, however WinNT is not nearly as user friendly than 98. Most PROs do prefer NT over 95/98 and many don't use windows at all. Like 3DSmax and Lightwave or Maya which handles threads far better than Carrara, they will use more server class OS's to expand the boundaries of thier resources to serveral computers. Also Duals are many times better than single processors depending on what APP you are running. Carrara has SHITTY threads but it does run 1/3 times faster on my dual than my single. If the program was finished upon release, I am sure it would have run faster but it's okay.
