Mon, Dec 2, 9:09 PM CST
Subject: Poser5 with Widows 2000
Niles ( ) posted Sat, 10 May 2003 at 9:43 AM ยท edited Mon, 02 December 2024 at 8:57 PM
I just installed P5 on one my of older PC, which I upgraded. I installed P5 from the CD, Sr3, and updater. P5 installed OK, ... but on the first render, I noticed I do not have the "Render Cancel" pop up. I loaded Judy,Don,Will,Penny all with Hair and 3 lights. When I clicked render nothing happened, no render cancel box no little blue bar, no adding objects, no rendering shadows ect... but It was rendering and it finished the render. Is there a window option I need to open, so I can see the render statues? This Pc only has basic stuff, Poser is the only program on it.
EricofSD ( ) posted Sat, 10 May 2003 at 1:22 PM
That hasn't been a problem for me with P5/win2k. Actually, the render box shows just fine with any of the service patches. It doesn't cancel very well, but I do get to see the progress bar.
Niles ( ) posted Sat, 10 May 2003 at 1:31 PM
Also my material room window is huge, and I can not scale it down.
khelben ( ) posted Sat, 10 May 2003 at 1:59 PM
You could try resetting your setting to factory default. It's in one of the menu options. If that doesn't work try deleting your .ini or .xml file in Runtime/ui or maybe Runtime/prefs. I can't remember. I do it quite often though so let me know if you can't find it and I'll look from home. HTH, Khelben
uli_k ( ) posted Mon, 12 May 2003 at 1:18 PM
Try canceling the with the ESC key, it might work better. On the UI problem: Please post your resolution and whether you have set the Interface Preferences to launch to factory state or to previous state (Edit->General Preferences). khelben's advice sounds good, you should try setting your Interface Preferences to launch to previous state. Then go to Runtime/Prefs and delete the XML file with has your resolution in its name, but not the word 'Default'.
