Have you moved the original files? sometimes upgrades look for items to be in default locations. I don't have the original, I'm off to go grab the full version of 2.0. hope thats the problem and you get it working. an email to daz will get answered just prob take a few days, don't know that they answer questions on weekends.
Yep..I had the flip hair installed to P4 but wanted the upgrade in P5...copied/pasted the geometries/zygotehair/ folder to Poser5/runtime/geometries and it worked. Could have just copied zygotehair/*.obj file, but I was in a hurry and did the entire folder...
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
so....is it worth having Both versions? I can spend $5 more and get old, then upgrade. I'm just not sure if it's a replace v2 kinda thing, or a different kinda thing. would I want to use the old one? does this question make any sence to any one but me? I guess I'm asking: I am gunna buy v2 looks cool, for $5 more I can get old, and get new v2.0 upgrade and get 2 hair models. is it worth the $5 to get both, or should I spend the $5 on some PClub items instead?
Kozaburo has a fine texture set for the version 1 flip hair model (makes it look very good), so there is a sound argument for having both. http://digitalbabes2.com/ I'd lost my version1 flip hair file (and had actually forgotten I owned it until today), and this forced me to dig around and find it. I wonder what else I have in the depths...
My upgrade just isn't installing. MAde sure the original files were in place where they should be and called what they should be called, nada. Still won't install. I got my flip hair on the V1 CD when I bought it. Also, the only error file I get is previously installed files needed not found. Or something to that effect. Redownloaded the file and it still won't work. ProPack here.
In a world filled with causes for worry and
anxiety...
we need the peace of God standing guard over our hearts and
minds.
Jerry McCant
Machineclaw, I rarely use the old flip but there are some interesting lengthening morphs out in our FS that make it a kind of sexy Rachel Welch Valley of the Dolls sort of hairdo. I got the full version cause I expected trouble over install and with an extra Pclub discount, it was worth it to behassle free. Love the Mike options. Emily
Pretty weird. The upgrade wouldn't install for me even though I'd just installed my newly rediscovered flip hair version 1, (same reason outlined above). Then I remembered that I had an old Poser4 folder copied over from my previous computer. The flip hair was installed on that, so just for a laugh I thought I'd try and do the upgrade in there. And it worked! Now this is the same flip hair installed from the same exe file (I only ever had the one). The files read the same size down to the last byte. So I copied them into my newer Poser4 Zygote hair geometries folder, and sure enough Windows asked me whether I wanted to replace the existing files. I did so, and then the upgrade went ahead just fine. The only difference I can see is that the files from the old install of version1 give a 'modified' time of 01:00 (12/04/2000), whereas the files from the recent install of version1 (same exe file) give a 'modified' time of 00:00 (12/04/2000). Anyways, for whatever reason I can play now. If you have an older runtime with the flip hair in it, you could try this too. UPDATE: It appears that it IS the time on the file that is causing the problem. Subsequent to writing the above I started from scratch again but used a file properties changing utility and adjusted the time from 00:00 to 01:00 on the blMWFlipHair.obj file. After that the upgrade went ahead just fine. I can change the file properties from within my "PoserDesk" file utility (way better than Windows Explorer), but if you don't have that there are utilities available on the net. There's a shareware (with nags) here: http://www.segobit.com/fpc.htm I hope this helps someone(s).
Hi Mark, I apologize. Our initial installer was a bit too strict, it seems. Here is a link for downloading an installer that should work better for you. Please let me know if you need anything else. (link is obviously not posted here) -- So for anyone who is still having problems DAZ will give you a new installer (possibly just download the product again if its still in your 'Recently Purchased')
i tried installing the new flip hair upgrade. but it says that the required file cannot be found. of course, i do have the old version. i dunno whats wrong. frustating to have downloaded it for an hour and not install it immediately. anyone having the same problem?
