Tue, Nov 26, 8:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Before I start on the P4 Male Seams Guide...
SnowSultan ( ) posted Tue, 06 June 2000 at 11:05 AM · edited Fri, 22 November 2024 at 6:18 PM
Just a quick question for you all - I've heard that the P4 Male texture template included with Poser 4 is not accurate. Is this true, and if so, has a corrected one been created? I need to have an accurate one before I can work on a seams guide, or it will be useless. Thanks, and thank you again for all the positive feedback on my other seam guides. :) SnowS Hoping his pictures are worth 1001 words.
my DeviantArt page: http://snowsultan.deviantart.com/
I do not speak as a representative of DAZ, I speak only as a long-time member here. Be nice (and quit lying about DAZ) and I'll be nice too.
Anthony Appleyard ( ) posted Tue, 06 June 2000 at 2:25 PM
Use my GETCOLTX to make a texture map template. It is in the Poser Free Stuff.
momodot ( ) posted Tue, 06 June 2000 at 5:53 PM
If I make a new Map for a figure using UVmapper for instance, where is the info linking each point on the mesh to its rlated point on the texture map kept? in the .obj file itself?
SnowSultan ( ) posted Tue, 06 June 2000 at 8:50 PM
Thank you Norkle, I was wondering where those went. However, I still plan to make a seams guide for the P4 Male, as I personally have had difficulty using those guides accurately. Thanks anyway, I appreciate the link. SnowS
Anthony Appleyard ( ) posted Wed, 07 June 2000 at 2:34 AM
To Momodot :: this information is stored in the vt lines in the .OBJ file. The vn lines are directions at right angles to the surface to store the result of smoothing.
momodot ( ) posted Wed, 07 June 2000 at 9:15 AM
I am so happing finally knowing this! I had been wondering about the "vt" and "vn" lines. Big thank you.
