Fri, Jan 10, 7:37 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Looking For Sources Of BVH Motion Files For Poser 4 and 5 Help!
danny7 ( ) posted Thu, 15 May 2003 at 10:18 PM ยท edited Mon, 23 December 2024 at 7:24 AM
Does anyone know of any sources from where I can find some BVH motion files for Poser 4 and 5? I mean, besides PoseAmation. Not that I don't like PoseAmation's stuff, but I'm wondering if there are any motherlodes of BVH files anywhere else that anyone knows about.
EricofSD ( ) posted Thu, 15 May 2003 at 10:32 PM
danny7 ( ) posted Fri, 16 May 2003 at 12:25 AM
OK, I found more Links to BVH files at the above link than I know that to do with. Thanks! However, a lot of the files are actually text files. Is there any way to convert them to .bvh files?
EricofSD ( ) posted Fri, 16 May 2003 at 12:52 AM
The ones from stanford (santamonica) are the best for getting started. I have some advanced bvh links if you get tired of those.
lesbentley ( ) posted Fri, 16 May 2003 at 1:01 AM
BHV file are text files, make sure the file extention is "BHV", if it's not change it.
danny7 ( ) posted Fri, 16 May 2003 at 3:18 AM
Great! uh, how do I go about changing the file extension in Windows XP?
Desdemmonna ( ) posted Fri, 16 May 2003 at 4:40 AM
control panel-->folder options-->view scroll down a bit and uncheck 'hide extensions for known file types' hit apply. Don't forget to check the box after your done, file extensions can be a major pain in the bum when your renaming files in your day to day activities...
SothArtist ( ) posted Fri, 16 May 2003 at 9:00 AM
Hehe I just downloaded one of those bvh files and Koz's long hair started marching across the screen leaving Vicki behind!
Dale B ( ) posted Fri, 16 May 2003 at 2:49 PM
An easier way would be to right click on the screen and use the 'Save As' function. Then it should come through with the proper extension. And what links are those, Eric? Hmmmmm? Oh, and be prepared to get =very= friendly with the graph editor and keyframe editor....
Little_Dragon ( ) posted Sat, 17 May 2003 at 7:01 AM
SothArtist:
Select the intended figure first, then import the .bvh file. :) It gets applied to whatever figure is currently selected (in your case, the hair, I'd assume).
