Well, there you go. I just tagged a suggestion to make a post like this on the end of the last thread. You're doing better than you let on. I'd say negative Heart-shaped face. I'm guessing you started with Posette rather than Vickie. If so, there is a 'cupid's bow' upper lip morph out there; if it's Victoria then the outer corners of the mouth would be easier. I don't think the nose is that far off, but the crease between the lower lip and chin seems low. Fuller lower lip? Try holding your hand over the top half of both faces and then the lower half and I thnk you'll see that the bottom needs the most work. Select the eyes, scale up and move them back on the z-axis to increase the size of the iris. There are replacement eyes if you want more detail there. No mention of your one week deadline in this thread. Good luck.
Thanks to ALL for the very helpful and constructive remarks. Momodot especially, thanks for the words weve shared via email on this. BTW - that hair is free from Kozaburo
s site - one of his amazing reworkings of Grays bob/flick styles. More work on her today implementing these changes, then a start on Lipsyncing soundfiles so the rendered anims come in within the deadline... This community is like nothing I
ve seen before. Long may it continue. Without it, this would be too far off the mark to even post ;-)
![file_128594.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_128594.jpg)
Well, this is the result so far. Still plenty to tweak admittedly, but given a few more goes it should be a little closer. Oh, and does anyone know of any transmapped hair like that anywhere?
