Fri, Jan 10, 10:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Can't Get A Texture Map to Apply to a Prop
pookah69 ( ) posted Mon, 26 May 2003 at 3:18 PM ยท edited Sat, 04 January 2025 at 11:12 AM
I downloaded a director's clapboard from 3D cafe. It is a 3DS file, which I've saved in my props library. I create a texture map and apply it to the prop, and for some reason it will not show up, even when I render the image. Is there any reason why texture maps would not "stick" to a prop? I tested the texture map by applying to other props, and it works fine. Why is this prop being so stubborn??
tasquah ( ) posted Mon, 26 May 2003 at 3:34 PM
Did you bring the prop into UV mapper and check to see how it was mapped ? Could be it need to be remapped to work right. Export it back out of poser as a OBJ fix the uv and reimport it back into poser might help.
pookah69 ( ) posted Mon, 26 May 2003 at 3:41 PM
How do you remap and fix the uv?
pookah69 ( ) posted Mon, 26 May 2003 at 3:46 PM
Actually, I just figured it out, and it works! Thanks for your help!
dialyn ( ) posted Mon, 26 May 2003 at 3:47 PM
Would you mind sharing the answer? It might help someone else.
pookah69 ( ) posted Mon, 26 May 2003 at 3:50 PM
Yes. I opened it in UVMapper, under "Map" selected "Planar", under "Tools" selected "Fix Seams" Then under "File" I selected "Export." Then in Poser, I imported the object, and was able to apply a texture map. D
dialyn ( ) posted Mon, 26 May 2003 at 3:57 PM
Thanks! :)
tasquah ( ) posted Mon, 26 May 2003 at 4:10 PM
good job pookah69.
