Tue, Feb 4, 11:46 PM CST
Subject: saving issue .... pls. help!!!!
nish ( ) posted Mon, 26 May 2003 at 10:27 PM ยท edited Mon, 27 January 2025 at 9:04 AM
I'm trying to render a picture in "Broadcast" mode ... well, I do manage to finish the rendering, but when I right click and try to save, Vue crashes! Rendering in Final is not giving me the best results. This is the biggest picture I've worked on, so far. Don't know if they will be much help, but the numbers are ... lil' over 4400 objects, 32 lights and about 10 mil polys'. The first Q. arise, whether my PC is capable of such render ... it has, P4, 1.4 GHz, 640MB ram & O/S is XP. Considering the Vue factors - it has the latest updates & Open GL is disabled. Since, it doesn't crash in the middle of the render, I'm lost and frustrated! Any suggestions, please!
sittingblue ( ) posted Mon, 26 May 2003 at 10:34 PM
You could try 'render to disk' under the Render destination controls in the Render Options dialog.
Have you tried saving the render using ctrl-f8?
Charles
Charles
dbigers ( ) posted Mon, 26 May 2003 at 10:49 PM
Try clicking the close button on the finished picture. Then try using the export picture function on the menu. Dont know if it will work, but maybe worth a shot. Donnie
nish ( ) posted Mon, 26 May 2003 at 11:40 PM
'Render to disk' sounds like a possible option (this will be 4th render). Ctrl-F8 didn't work, same about the close button and export. Thanks for your help.
