Mon, Feb 10, 8:30 PM CST
Subject: Under and overwater
zxcvb ( ) posted Sun, 25 May 2003 at 4:59 PM ยท edited Mon, 10 February 2025 at 10:11 AM
Hi can any one help me i have been trying to create a underwater and overwater image in vue 4.
i have seen some excellent images done this way in vue, have been trying but no luck as yet
Thanks for any help or advice
andy(zxcvb)
gebe ( ) posted Sun, 25 May 2003 at 5:14 PM
ShadowWind ( ) posted Tue, 27 May 2003 at 1:32 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=381182
In Orca Fantasies I took a bit of a simpler approach than the tutorial, more based on Wabe's technique, which is to place a large regular plane with a water texture and place the camera lens at the very edge of the plane. How close depends on a number of different factors and what effect you are going for, but it should be fairly close (if not almost right on it). Another trick I learned while doing that image was to place a long cube (the width of the plane) under the water on the opposite edge of the one on the camera. The cube should be a bluish or greenish color so it doesn't look out of place. This has a profound effect on the fogging that Vue does and will create that underwater fogging quite well, while leaving the top with less fog. You will want to have fog and haze turned up especially at the lower altitudes. Then it's just a matter of caustic lighting and such...
Diagram:
v--Camera
]--------------------- <-- plane with water texture
....................[] <-- cube (ignore the periods)
---------------------- <-- infinite ground plane
Hope this helps. If ya have any other questions, feel free to IM me...
ShadowWind
