Thu, Jan 9, 8:10 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: Anything Grows as a particle generator
marcq ( ) posted Mon, 26 May 2003 at 10:34 AM · edited Thu, 09 January 2025 at 6:54 AM
I recently posted a picture of a dryad in the four seasons and found Anything Grows to be very useful beyond just the grass and flower use.
For instance in the attached picture, the petals in her hand (can't see too well in this angle but it is a little mound) as well as the ones falling from her hand in front of her use Digital Carver Guild's anything grows with invisible stalks/base to place the petals.
In another scene, I use AGr to place fall leaves on terrains.
I tried to use Agr to make sort of a lumpy snow look using little half-dome objects. Turns out to be the perfect technique for modeling cauliflower if anyone has a pressing need for that ;-)
I didn't use it in the pic but earlier tried a swoop of petals coming from behind the dryad where I used the AGr width shader to make the more distant one smaller for a nice depth effect. I use the width shader in the flower and grass behind the dryad to provide some depth.
Also found Anything Grooves useful for the snow in the winter scene where I could use the wave shaders to get some snow banks.
Anyway, I found Anything grows to be much easier to control than the particle generator and you can use it to place any type of object. For static images (which is all I do), it is much nicer. Heres to the AGr particle generator ;-)
Marc
Hoofdcommissaris ( ) posted Tue, 27 May 2003 at 2:25 AM
Residing slightly underused in my toolbox I just decided to dive seriously into this excellent plugin. I am creating a fairy tale house & dwarf situation. I think you just inspired me to incorporate a swarm of bees. And falling leaves.
marcq ( ) posted Tue, 27 May 2003 at 10:50 AM
When I purchased Anything Grooves and Anything Grows, I thought I would use Grooves everywhere and Grows just a little. Due to the conflicting need for resolution and managable facet counts, I don't really use Grooves that much. But Grows has become indespensible. It is my most used plug-in by far. With the tip feature, you can use it for endless things. Should work great for bees and falling leaves! Marc
