Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
The floor tex looks a bit too rough and irregular. Stone floors were usually better dressed. A rough plank floor is more likely on a tower or upper level room. The walls are too thin. Most castles (or fortified houses) had walls that were several feet thick. Even at the upper level it would still be visibly thicker than the frame of your window. I would add some ceiling beams as well and a different texture. I would also see about more items to put into the room. If they had glass they were well off and it was an important room. See comment regarding stone dressing and furnishings. There is potential here and I look forward to seeing where you go with it.
