Fri, Jan 31, 7:57 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 3:43 am)
Subject: I have a simple question
nyguy ( ) posted Thu, 29 May 2003 at 10:00 PM ยท edited Fri, 31 January 2025 at 7:40 AM
I have created a prop, all of the joints are correct but I want to have a link between parts ot the prop. Wen I move one part I want the other part to move a certian way. I cannot find the info in the novel (manual) that CL sent with Poser 5. Can one one help?
Poserverse The New Home for NYGUY's Freebies
MachineClaw ( ) posted Thu, 29 May 2003 at 10:14 PM
you need to read about the Setup Room and joints. the joint editor is pg 213 in the poser 5 manual. you can set limits to the joints and directions they can 'bend' etc. I haven't used it all that much, but there is a tutorial in the manual about making a character in poser and the steps to do it. I would read this section. hope that helps a bit.
Wizzard ( ) posted Fri, 30 May 2003 at 4:30 AM
also check at 3dmenagerie Bloodsong was working on something simular.. another place to look would be Nerd3d.. especially the ECM section.. there should be links to the side to both sites... if not... http://www.3dmenagerie.com/ http://www.nerd3d.com/nerd3d.htm justin case CHeers
