Fri, Nov 22, 9:59 PM CST
Subject: experiment with light and KPT6 equalizer
Lorraine ( ) posted Sat, 10 June 2000 at 10:56 PM ยท edited Fri, 22 November 2024 at 9:37 PM
This image is the result of an experiment with lighting along with the equalizer in KPT6, uses viki pose, zygote ponytail hair, viki; some interesting effects using kpt6 and adjust the transparancy in photoshop.
wyrwulf ( ) posted Sat, 10 June 2000 at 11:29 PM
Looks really good, Lorraine. It would make a good style of work.
momodot ( ) posted Sun, 11 June 2000 at 11:26 PM
Very nice. but what aspect exactly is the KPT responsible for? What do you do with it? Is it what gave the beautiful uminance/translucence somehow?
Lorraine ( ) posted Mon, 12 June 2000 at 4:32 AM
The KPT6 equalizer gave the image a softer brighter transition between the color and shadow. Also I used the depth cueing to start with, which gives a less bright beginning image. the equalizer has a series of controls which vary the sharpness and brightness. In this case the controls were adjusted so the image became less sharp, more bright emphasizing the lighted portions then using the transparancy of the duplicated layer adjusted it until there was a subtle shift in the depth and softness of the image. So in short, KPT6 gave the luminance/translucence or added to the illusion of a glowing of light rather than the harsh "lighted" affect.
Larry F ( ) posted Mon, 12 June 2000 at 4:35 AM
That's very beautiful!
momodot ( ) posted Mon, 12 June 2000 at 10:31 AM
Really it is a great ambience. Very artistic. Thank you for explaining it. `dan
