Mon, Feb 17, 9:55 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 9:52 am)
Subject: Poser imported background image
Karma ( ) posted Sun, 01 June 2003 at 3:56 PM ยท edited Tue, 28 January 2025 at 4:31 PM
I imported a background image into poser 5 (a sky texture) didn't look right, but I had already made my scene. What I would like to know is how I get rid of that imported background image without restarting my scene.
Scathdebas ( ) posted Sun, 01 June 2003 at 3:59 PM
I think it is under edit, but there is a clear background image menu item.
Karma ( ) posted Sun, 01 June 2003 at 4:01 PM
Thanks a bunch!! :)
Little_Dragon ( ) posted Sun, 01 June 2003 at 4:03 PM
If you imported the image from the File menu, then: Display menu --> Clear Background Picture If you added the image from the Material Room by hooking up an image node to the Background, you'll have to disconnect it manually.
caulbox ( ) posted Mon, 02 June 2003 at 1:54 PM
Also, if you want to save your final image and still have the option of changing the background later... then save the image as a TIF file. Poser will generate an alpha channel which will allow you to replace the background (in your usual paint program) even after the image has been saved.
