Thu, Dec 26, 8:35 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Poser 5 to Poser 4 question
fiction2002 ( ) posted Tue, 03 June 2003 at 12:03 AM · edited Thu, 26 December 2024 at 8:34 PM
Greetings everyone, I'm working on a new prop set for Poser, and I have one concern. I'm developing it under Poser 5. Will the Poser 5 cr2 and pp2 files work under Poser 4? I'm having trouble stripping out the Poser 5 specific data, but if they'll work under Poser 4 anyway, I may as well keep them as they are. If anyone knows, I could use the help. Thanks! Jonathan / fiction2002
Marque ( ) posted Tue, 03 June 2003 at 12:12 AM
It should open under 4 with a warning that it's a newer file. Marque
fiction2002 ( ) posted Tue, 03 June 2003 at 12:13 AM
Yay! Thanks for the info. Then I guess this set is ready for the Marketplace. :-)
Wizzard ( ) posted Tue, 03 June 2003 at 12:51 AM
about the only thing you'd have to do for Poser 4 would be to include image rsr's for the figure/props.... p3do from senosoft can do that easily for ye. and a word in the readthis about converting the jpg's to bum's for the bump maps 8 ) good fortune 8 )
TrekkieGrrrl ( ) posted Tue, 03 June 2003 at 1:25 AM
Oh and if you change the version number in your pp2/cr2/whatever to 4.01, Poser 4 users won't get that "Newer version than expected" error. And Poser 5 doesn't care :o) Note that Poser 5 files are bigger than Poser 4 versions due to all the unneccesary (for P4 users) cr*p specific for P5. So if you have any way of stripping them, it would be an advantage imo. Good luck :o)
EricofSD ( ) posted Tue, 03 June 2003 at 1:28 AM
The error goes away after you resave in P4 and then reopen. I don't know what exactly gets changes, might still need to hack the cr* but at least you can offer it and it should work with both versions.
fiction2002 ( ) posted Tue, 03 June 2003 at 1:57 AM
Thanks everyone. I've changed the version number in the pp2s and cr2 to 5, and created rsrs for them as well. I think it's good to go! Best, Jonathan / fiction2002
TrekkieGrrrl ( ) posted Tue, 03 June 2003 at 2:56 AM
EricofSD you're right of course but I think that having to do so is something acceptable for free stuff but not for commercial items. Remember when you save something to the palette again you also make a new thumbnail, and unless you're very carefull what's in your picture at the time, you can end up with an ugly/unuseable thumbnail. fiction2002, I hope it was a typo when you wrote that you changed it to 5? :o) Also for some reason it has to be 4.01 and not just 4.
fiction2002 ( ) posted Tue, 03 June 2003 at 1:20 PM
LOL... yes, that was a typo. I changed it FROM 5 to 4.01. Thanks for pointing that out. :-) Jonathan / fiction2002
