Wed, Jan 22, 10:43 PM CST
Subject: Need help with Injection Pose Builder (face / body)
A_ ( ) posted Mon, 02 June 2003 at 3:34 PM ยท edited Wed, 08 January 2025 at 1:36 AM
Okay, it's quite late and I'm not sure how well I can explain my question, so I'll just try an example. :) I created a V3 character "A" using Daz's morphs (full body and head morphs) and a character "B" (also full body and head morphs). Now I want to be able to use A's head on B's body and the other way around. So I'm guessing I should save the body morphs and the face morphs as a different injection pose file. So far sounds logical. :) So I take character A and I turn all of the head morphs I used to Zero. I save my character as "A body" (after using the "!IPB prep") and then take it to the IPB and create a pz2 called "A body INJ". This pose works ok. Now I take my original A character and turn all of the body morphs to Zero, use the "!IPB prep", and save it as "A head". Then I take it to IPB and create a pz2 called "A head INJ". Now I go to Poser, I load a fresh V3 and click on the "A body INJ". So far so good. The body loads fine. So next I click on "A head INJ", and that's the problem. :) The body morphs disappear, and the head morphs appear. But they cannot be both. So I try to save "A head INJ" as a fc2, but the file doesn't show in Poser. I mean, when I open the windows explorer, I can see the file "A head INJ" in my "face" directory inside the library I created, but when I load Poser it looks as if this library is empty. So what am I doing wrong??
rbtwhiz ( ) posted Mon, 02 June 2003 at 4:11 PM
In IPB 1.0, use the option "Strip Zeroed" in the general processing dialog to ignore all of the zeroed channels... When saving into the face library, be sure that you use the fc2 extension in order for it to show up in poser. Poser does not see pz2's in the face library folders.
If it can wait a day or two, IPB is getting an update. One of the additions I've made specifically address this scenario.
Build History (directly from my code comments):
Version 1.1.1.0 (6/02/2003)
Features:
** Hot Keys **
- F1 = Help
- F2 = Toggle Figure Palette
- F3 = Toggle Add-On Palette
- F4 = Toggle General Processing Palette
- F5 = Manual readScript Insertion
- F6 = Re-process Source File
- Ctrl O (Win) | Cmnd O (Mac) = Open File
- Ctrl S (Win) | Cmnd S (Mac) = Save File
- Ctrl Q (Win) | Cmnd Q (Mac) = Quit
- Middle Click (Win) | Option Click (Mac) = File Menu
- Right Click (Win) | Control Click (Mac) = Option Menu
** File IO **
- Compare source for change prior to prompting for save
** General Options **
- Read Options File
- Save Options File
- Default Options Restore
** Options File **
- Record position of main window and option palettes
- Record size of main window; option palettes auto size
- Record option state for option palettes
** Processing **
- Recursive Batch Processing
- Create INJ and REM Pose Simultaneously
- Create REM from INJ Pose
- Record Master Actors Only (BODY/head)
- Record Body Actor Only
- Record Head Actor Only
- Record Expressions Only
- Record | Omit Scale Channel Values
Bug fix:
** General Processing **
- Record | Omit Delta and Visibility Information
- Record | Omit Expression readScript Entries
** Victoria 3 Support **
- Anna-Marie Source Path
Version 1.0.0.0 (2/25/2003)
Features:
** File IO **
- Parse cr2 | pz2 | fc2
- Create pz2 | fc2
- Append File Contents - At Cursor | After line | At End
- Clear (Display) - Above | Below Text Cursor
- AnnaMarie Goddard Digital Clone
- Morph Expansion Pak 1
- Horn Pak
- Male Morph Pak
- INJ | REM Pose Creation
- Record | Omit Input readScript & Comments
- readScript for Non-Zero | for All Channels
- Round Thousandths Place (.001)
- Convert Exponential Values to Absolute (Round Thousandths)
- Record | Omit Expression Channels
- Record | Omit Zero Value Channels
- Record | Omit Channel Values
-Rob
Spit ( ) posted Mon, 02 June 2003 at 6:48 PM
IPB is a must-have! Just a heads up for PBoost users. I've found that if I deal with files directly in Poser sometimes a lock gets put on the folder (at least in XP/NTFS). To get around that I just move the poser files I want to work with to a temporary folder and use that. Then move 'em back to Poser when finished.
A_ ( ) posted Tue, 03 June 2003 at 2:03 AM
Thank you!
A_ ( ) posted Tue, 03 June 2003 at 2:32 AM
Well, it still doesn't appear in the face folder, but if I save it as pz2 in the pose folder it works fine (I think..). I don't think it's saving it as a fc2 even when I tell it to save it as a fc2. Well, guess I'll just have to wait for that update. :) Thank you once again.
rbtwhiz ( ) posted Tue, 03 June 2003 at 1:09 PM
You must specify "[your name].fc2" (be sure to include the .fc2) in the save dialog and navigate to the Runtimelibrariesface[your catagory] folder when you save the file, in order for it to show up in Poser. Simply selecting "Face File (*.fc2)" from the file types drop-down will not change the extension for you.
Beta feedback has been great, so the update should be posted later today... :)
-Rob
A_ ( ) posted Tue, 03 June 2003 at 1:23 PM
Oh, now it works! How did I not think of writing down "fc2". :) Thanks again. :)
rbtwhiz ( ) posted Tue, 03 June 2003 at 1:36 PM
No problem... Actually, I'm glad the question came up... because it prompted me to look for an anomally in my code for the Mac version with regard to type and creator information (which has now been fixed). -Rob
