Tue, Nov 26, 5:06 AM CST
Subject: Use 'Export as morph' to create multiple MTs
bushi ( ) posted Tue, 13 June 2000 at 6:05 PM ยท edited Sat, 16 November 2024 at 2:00 AM
I don't think I've seen anyone post this technique. If so, sorry to be redundant. Using the 'Export as Morph Target' feature in 402 you can morph several objects at the same time. Using this method with clothing results in MTs for the clothing that mimic the main figure's MTs. Here's how it's done: 1. Place a Poser figure. Then add a piece of conformable clothing and conform it. 2. Select 'export as .obj' 3. In the parts pop-up select the Poser figure part and the clothing part. 4. In the export pop-up check all options except 'weld' and then export. 5. Import the .obj into your 3D modeling program. 6. Select the vertices for the morph through both meshes. In some modelers you may have to group the meshes. 7. Create your morph. 8. Export the meshes seperately. 9. Apply the meshes as MTs to the figure and to the clothing. The applied MTs will be very similiar in shape as you adjust the dials. I tried this using just the bikini top but see no reason why you couldn't layer several pieces of clothing. Doing so would result in clothing MTs that all work the same as the main figure MTs. I've put an animated .gif file of the result of the first test. You can see it at: http://bushi3d.com/images/MultiMorph1.gif It's about 585K so be warned.
Lemurtek ( ) posted Tue, 13 June 2000 at 7:31 PM
Thanks for posting this! Great technique!
wyrwulf ( ) posted Tue, 13 June 2000 at 11:27 PM
Great tip, Bushi. Thanks.
LoboUK ( ) posted Wed, 14 June 2000 at 5:02 AM
That's terrific bushi - an excellent technique that's going to make life much easier. Thank you for posting it Paul
arabinowitz ( ) posted Wed, 14 June 2000 at 8:43 AM
I wish I could try it, but the last patch (118, I think) has some sort of bug that doesn't allow you to check off any of the boxes except 2 of them. Does anyone know how to get around this?
-renapd- ( ) posted Wed, 14 June 2000 at 4:53 PM
Site Admin Online Now!
Just WOW!!!!! master! :o)
[[MyGallery] [MyStore]
"Collect moments, not things."
bloodsong ( ) posted Wed, 14 June 2000 at 5:48 PM
heyas; i have the 118 patch and i don't have any trouble checking any obj export boxes. you might get the final patch and try that (er, yeah, i'll install that someday...). or else delete everything in the poser plug-ins directory and reinstall your 118 patch. bushi! what a great idea! thanks :)
arabinowitz ( ) posted Wed, 14 June 2000 at 10:14 PM
Ithought 118 was the final patch. Whats the number on the final patch? other people have experienced the same problem as I have, but noone seems to know what causes it.
bloodsong ( ) posted Thu, 15 June 2000 at 10:46 AM
heyas; i dont know what the difference is between 118 and the official 'final' patch (maybe just the packaging?). but it's at um... ghost effects, isn't it, guys? i know that getting duplicate export options is a symptom of not deleting the old plug ins before patching... and i thought that symptom also came with the unavailable checkboxes as well. you can't have those old plug in files anywhere on the same hard drive as poser. (picky, but true.)
Lemurtek ( ) posted Thu, 15 June 2000 at 3:35 PM
The 'Official' patch can be grabbed from Curlious Labs: http://www.curiouslabs.com/ under downloads
arabinowitz ( ) posted Thu, 15 June 2000 at 5:08 PM
I deleted the plugins before I updated. I emailed Larry weiberg, and he said he would look into it. I'll let you all know what the outcome is.
