Sun, Jan 12, 9:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Silly question!
wrecker25 ( ) posted Tue, 13 June 2000 at 3:16 PM ยท edited Thu, 09 January 2025 at 1:44 AM
How do you basically attach an obj. (3ds, obj, dfx, etc.) to a poser part (hand, foot, head, etc) Example: I want to attach a sword to my figure so when I move his arm, I don't have to manually reposition the sword. I have been racking my brain on this. HELP!
Roshigoth ( ) posted Tue, 13 June 2000 at 3:24 PM
Parent the sword to the poser figure's hand. =) Rosh
bloodsong ( ) posted Tue, 13 June 2000 at 5:16 PM
heya; what rosh means is... select the obj or prop or whatever it is, then hit ctrl-i. (object:properties) there should be a button that says 'set parent.' hit that, and select the body part to be the obj's parent. also, it might help if you lock the object (object:lock object) after you do this, so you don't accidentally grab the prop when you mean to grab the hand.
wrecker25 ( ) posted Wed, 14 June 2000 at 9:47 AM
Thanks, I'll try that. I think what I was doing wrong was using "Set new Parent". When I did that the object would move with the body part, only it would offset about an inch and a half (On-Screen).
bloodsong ( ) posted Wed, 14 June 2000 at 5:34 PM
heya; it might do that, anyway. just grab the prop and drag it back where it belongs, THEN lock it. that's just... one of them poser thangs. ;)
wrecker25 ( ) posted Fri, 16 June 2000 at 10:06 AM
K thanks
