Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 8:20 am)
heya; what rosh means is... select the obj or prop or whatever it is, then hit ctrl-i. (object:properties) there should be a button that says 'set parent.' hit that, and select the body part to be the obj's parent. also, it might help if you lock the object (object:lock object) after you do this, so you don't accidentally grab the prop when you mean to grab the hand.
How do you basically attach an obj. (3ds, obj, dfx, etc.) to a poser part (hand, foot, head, etc) Example: I want to attach a sword to my figure so when I move his arm, I don't have to manually reposition the sword. I have been racking my brain on this. HELP!
