Fri, Jan 31, 6:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: What is the system requirement for running Poser?
baoling ( ) posted Sat, 07 June 2003 at 4:32 AM · edited Fri, 17 January 2025 at 10:27 PM
I don't know is it because my computer too old? Everytime I start Poser, I need to wait for a long time before I can use it. So what CPU? Graphic Card? or RAM? is appropriate for runnig poser?
Chris ( ) posted Sat, 07 June 2003 at 4:43 AM
What computer you have? I'm running a Xeon 866 MHz with 512 MB RAM and a GeForce 2 videocard. Poser 4 starts within 5 seconds but Poser 5 needs up to 30 seconds to start on my system. For use Poser 4 you should have a PII or better with a minimum RAM of 256 MB to run it smooth. For Poser 5 I have to say the faster the better and much RAM. I hope that helps a little bit Chris
"It Is Useless To Resist!" - Darth Vader
Axe_Gaijin ( ) posted Sat, 07 June 2003 at 5:22 AM
I just timed my poser 4 pro pack start up. From the moment of double clicking the desktop icon to where it's ready to start; 54 Seconds. Athlon 2100+ %12MB Ram, running Poser of a 14Gb partition with 5.7Gb Free space on htere. It does start up a lot quicker if I start it up a second time without restarting my PC in between. (After doing some caharacter creation I like to restart because all the textures loaded into the material files.)
Axe_Gaijin ( ) posted Sat, 07 June 2003 at 5:23 AM
That % is of course a 5.
steveshanks ( ) posted Sat, 07 June 2003 at 6:09 AM
i have XP on a 2.8ghz cpu with 512ram, and after booting up it takes quite a long time to start poser (any version, i have P4, P5 and PPP on this pc), i haven't timed it but i mean minutes rather than seconds, but after the first time it starts quick next time.......but on the old system of a pIII 700mhz it started in seconds and not much longer on the old 400mhz one, so it may be the OS as much as the machine itself.....Steve
Chris ( ) posted Sat, 07 June 2003 at 7:37 AM
hehehe ... I need to look more what I'm typing ... Poser 4 does not start within 5 sec ... it must be 25 sec :) Chris
tonymouse ( ) posted Sat, 07 June 2003 at 9:57 AM
As much as you can afford ;)Poser has a subroutine that analizes your bank account(s) and if you have money in it, it slows down till you upgrade and buy more models!!!!
DarkElegance ( ) posted Sat, 07 June 2003 at 10:37 AM
geeze it takes just over aminute for poser to open to use on my system. and sometimes takes up to 20 minutes to render some scenes. I have and old war horse she has a pentium celeron, 160 in ram. heh almost need a pull cord to start her.
https://www.darkelegance.co.uk/
Commission Closed till 2025
baoling ( ) posted Sat, 07 June 2003 at 11:21 AM
My system is PIII, CPU 300Mghz, RAM is 256MB. Is it suitable runing Poser 5?
BeatYourSoul ( ) posted Sat, 07 June 2003 at 11:31 AM
Very slowly... Here are Curious Labs System Requirements for Poser 5: English only versions of Windows 98se, 2000, ME or XP 500MHz Pentium class or compatible (700Mhz or greater recommended) 128MB system RAM (256MB recommended) 24-bit color display, 1024 x 768 resolution 500MB free hard disk space Internet connection required for Content Paradise BYS
sandoppe ( ) posted Sat, 07 June 2003 at 12:39 PM
Everyone seems to have different experiences with Poser 5 baoling. I have a Pentium IV, 1.7 ghz CPU, 512 DDR Ram on Windows XP Pro and it still runs pretty slow. It gets slower as the number of products you add increases :) I would think your system would have problems handling Poser 5, but I guess it depends on your level of patience, what you plan to use P5 for and what other things you do on your computer :)
