Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
It's a long shot, but check your root directory for an autorun.inf file. If it's there, rename it to autorun.xxx and reboot. Try to run poser and or install a program again. My friend had a similar problem on Win 98, and once I got rid of the autorun file, all was fine. Seems the autorun file makes Windows think it needs a CD to continue.
You may have a conflict with some of the startup crap Windows comes with or variables that install themselves when you add a new program/update an existing one. Two things you can do- Look in your 'Startup Folder' Start-->Programs that start when Windows start...most of the time you can safetly delete anything there thats unused. -or- Start-->Run. Type Msconfig This will bring up a little utility within Windows, hit the startup tab if the Divx player is one of the checked boxes, uncheck it and retart system...you can always run msconfig again and check the box. Worst comes to worst, you can always roll back the XP :)
Every time i try to open Poser, or ANY program in fact (well with the exception for a few) i get this stupid pop-up thingy. seen above! Why?!? does anybody know what it is? And sometimes when i tried to install things it pops up and says not enough memory or something like that. When in fact i have a lot of memory! what is up! I use a Windows2000 professional based computer. thanx
