Fri, Jan 31, 7:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Windows User Poll
brycetech ( ) posted Wed, 11 June 2003 at 8:49 PM · edited Fri, 31 January 2025 at 7:14 PM
hi The amapi tutorial cd nears its completion. It also gives some information on using amapi to create poser clothing and practical uses which would be of interest to the group here. I have written a little application that will help overcome a problem with the current versions of amapi when using it to create a symmetrical duplicate of a previously uv mapped obj model. Anyhow, I am going to be including this with the tute. To better help me understand how many people can actually use it "as is" (without an installer)...I need to know the following. Do you have the following file on your computer: "scrrun.dll" Just do a search for it from your start menu..it should be in your system or system32 directory. Including the runtimes will make it impossible for me to make this a downloadable tutorial...so I'm just feeling around to see if its really worth it to include this program with the tute. This dll is one that allows visual basic to use scripting to write files..for instance, once the program makes the mirrored duplicate of your model..it needs to be able to write it back to disk. If you dont have this file, it can't write to disk and you'd get an error. tia BT
Crescent ( ) posted Wed, 11 June 2003 at 8:54 PM
Yes - XP Professional, file located in: c:windowssystem32 c:windowssystem32dllcache File size 145KB, Date Modified 8/23/2001. Cheers!
LaurieA ( ) posted Wed, 11 June 2003 at 9:00 PM
Yup: XP Home, file located in: c:windowssystem32 same file size and date as above :o) Laurie
Little_Dragon ( ) posted Wed, 11 June 2003 at 9:14 PM
C:WIN98SYSTEM File size: 148KB File version: 5.6.0.6626
EricofSD ( ) posted Wed, 11 June 2003 at 9:48 PM
Yup, in several locations. Win2k pro.
lhiannan ( ) posted Wed, 11 June 2003 at 10:07 PM
WinMe, yes. System dir.
Chas ( ) posted Wed, 11 June 2003 at 10:53 PM
If it's integral to the use of your CD and you're worried about universality, you can always include mention of http://www.dll-files.com/ in your packaging. Anyone who doesn't have it can find it here. Take care; Chas
dialyn ( ) posted Wed, 11 June 2003 at 11:59 PM
My brand new XP Home has the file located in: windowssystem and c:windowssystem32
Ailarchendil ( ) posted Thu, 12 June 2003 at 1:20 AM
Yes - WIN98 in C:WINDOWSSYSTEM
bikermouse ( ) posted Thu, 12 June 2003 at 1:23 AM
XP Home, file located in: c:windowssystem32 File size 145KB, Date Modified 8/23/2001.
hauksdottir ( ) posted Thu, 12 June 2003 at 1:28 AM
WIN98, in Windows/System... but only 49KB, mod 6-26-01
igohigh ( ) posted Thu, 12 June 2003 at 2:06 AM
Got it here too, Win98SE c:windowssystem but I only have an Amapi 4.15
kawecki ( ) posted Thu, 12 June 2003 at 2:20 AM
No "scrrun.dll" in my Win95, I have very few visual basic runtimes installed and no applications done with visual basic, with the exception of old Windows 3.1 card games.
Stupidity also evolves!
almck1@hotmail.com ( ) posted Thu, 12 June 2003 at 2:23 AM
Yes. c:windowssystem
Migal ( ) posted Thu, 12 June 2003 at 2:38 AM
Yes, XP Pro. Same version as LD. I have your previous Amapi tute on CD. I'd much prefer a downloadable version for the next one, BT. I'm curious, does the new one you're doing get into version 7?
RHaseltine ( ) posted Thu, 12 June 2003 at 5:45 AM
Yep - XPHome, System32, 145KB version
RawArt ( ) posted Thu, 12 June 2003 at 6:11 AM
Windows 2000 pro Have this in 4 places Rawnrr
lundqvist ( ) posted Thu, 12 June 2003 at 6:37 AM
That DLL is the MS Scripting Runtime library, isn't it? It's been through a few versions in its time. I think that it gets installed/updated along with Internet Explorer (but then, what doesn't?). I found a copy in windowssystem32 as well (5.6.0.6626)
cruzan ( ) posted Thu, 12 June 2003 at 8:46 AM
98SE - windowssystem xpPro fat32 - Not found xpPro ntsf - windowssystem32
lesbentley ( ) posted Thu, 12 June 2003 at 8:47 AM
Yes. Win98 SE. Location: C:WindowsSystem Version: 5.6.0.6626 Date: 15/Feb/2003
Porthos ( ) posted Thu, 12 June 2003 at 9:58 AM
Win XP home Found in System folder
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
Jackson ( ) posted Thu, 12 June 2003 at 10:43 AM
XP Pro; yes It's in system32 and system32/dllcache. size: 147,483 modified 10/23/01
macmullin ( ) posted Thu, 12 June 2003 at 3:06 PM
win98 SE C:WindowsSystem version 5.6.0.6626
EsnRedshirt ( ) posted Thu, 12 June 2003 at 6:36 PM
Brycetech, you should check on the microsoft web site (I know, it's a horrible maze to navigate), but I'm sure they've got info on .dll's and distributions in a developer section somewhere. As for me, WinXP, latest version, in system32. .dll version 5.6.0.6626
Penguinisto ( ) posted Thu, 12 June 2003 at 6:53 PM
Yep - I got it, err, in my dll emulation directory within Win4Lin, but I, err, don't run Windows. :)
hogwarden ( ) posted Fri, 13 June 2003 at 5:13 AM
Yep, it's here, XPPro. But you can be sure that someone who downloads your tutorial won't have it and the support mails will start flooding in. Make sure you give really easy instructions on how to get the file and install it if it isn't there.... H:)
