Wed, Dec 4, 5:30 PM CST
Subject: Rotation question
Rennie ( ) posted Mon, 09 June 2003 at 2:41 PM ยท edited Wed, 14 August 2024 at 7:06 PM
Hi,
I want to render a little animation. To easily set up the correct scene I want to render I want to rotate something . I think it is done with the "track object" option, but i can't get it done. The pictures gives an explanation of what I exactly want. If i can get this done my scene setup will get a lot easier. Don't know if this is possible.
thnx in advance
Ren
clay ( ) posted Mon, 09 June 2003 at 2:58 PM
Turn on your "show origin" in the sphere and red bar's group attributes, then move the green origin point down to where the red and green bars meet, that should do the trick for ya.
Do atleast one thing a day that scares the hell outta ya!!
Rayraz ( ) posted Mon, 09 June 2003 at 3:59 PM
Do what clay said and make the green bar the parent of the red bar and the red bar the parent of the ball. Instead of moving the ball, you rotate the red bar and it should rotate around the origin while the ball sticks too it like glue.
(_/)
ringbearer ( ) posted Mon, 09 June 2003 at 4:46 PM
When you move the origin handle you can constrain to either x,y,z axis by holding either x,y,z letter on the keyboard. Arleen
There are a lot of things worse than dying, being afraid all the time would be one.
Doublecrash ( ) posted Mon, 09 June 2003 at 5:38 PM
Good, Arleen! I didn't know it! :)
ringbearer ( ) posted Mon, 09 June 2003 at 7:41 PM
Glad to help!! Arleen
Rayraz ( ) posted Tue, 10 June 2003 at 1:08 AM
didn't know that either. Thanx.
(_/)
Rennie ( ) posted Sat, 14 June 2003 at 12:23 PM
Quote - When you move the origin handle
Sorry i don't know what you mean by that. Sorry for the delayed. reply
Aldaron ( ) posted Sat, 14 June 2003 at 1:06 PM
The origin handle is the little green dot in the center of the object or group that appears when you go into attributes (the little "a") and set "show origin handle". this is the point that the object/group rotates around. If you move it then it rotates at the new point as clay suggested above.
Rennie ( ) posted Sat, 14 June 2003 at 1:47 PM
Yes it is working! Thank you so much for the help!
