Fri, Jan 24, 1:30 PM CST
Subject: mapping pictures
satfj ( ) posted Mon, 16 June 2003 at 11:46 AM ยท edited Thu, 09 January 2025 at 2:41 PM
I have a jpeg I want to map on a surface (surface is 100x50 scale units) in vue. My jpeg is 100px X 50px which means my jpeg should fit exactly on the surface. I dont want to tile it I just want one image to fit. How do I make it fit one to one? Does it have to be trial and error? Thanks
sittingblue ( ) posted Mon, 16 June 2003 at 1:00 PM
Check out MightyPete's tutorial on terrain mapping: http://www.petes-oasis.com/hummingbird.html Charles
Charles
satfj ( ) posted Mon, 16 June 2003 at 6:48 PM
Sorry for the misunderstanding when I said surface I ment material surface such as on an object or box rather than terrain.
gebe ( ) posted Tue, 17 June 2003 at 9:27 AM
You better do it in UVmapper then:-)
gebe ( ) posted Tue, 17 June 2003 at 9:30 AM
BTW, you did not give us anough details. What kind of object exactly? Is it a Vue primitive (then see in the FAQ tutorials section). Is it an imported OBJ (you need UVmapper). Show us the bitmap and the object. This would be much easier to answer. Guitta
satfj ( ) posted Tue, 17 June 2003 at 11:30 AM
It's an imported object created in 3D Studio Max. Shouldn't it export it with UV maps already?
gebe ( ) posted Tue, 17 June 2003 at 11:33 AM
Yes, this should work if you export it as a 3ds.
