Sun, Jan 12, 7:10 AM CST
Subject: Lights in windows?
Diandra ( ) posted Thu, 19 June 2003 at 9:10 AM ยท edited Sun, 24 November 2024 at 3:17 AM
Could someone tell me the best lights to place in a buildings windows to achieve a soft lit glow in each window? Thank you for your thoughts, tips and/or tricks to achieve this. Diane
Kutter ( ) posted Thu, 19 June 2003 at 11:02 AM
Tricky question Diane, because they will all pretty much do the job. If your looking at several windows that need this soft glow you'll probably be better off useing point lights behind each (Tip: use a gel on them to break up the light a bit and create soft shadows) But of course you can only do this if the inside of your building actually has seperating floors and walls (else they will all mingle together) If thats the case use spotlights angled the same way out of each window. This way you can just aim the cone where you want it to be (into the garden or whatever) The quad lights act strangly sometimes (although I havn't had a lot of call to use them so I'll shut up now before i make a fool of myself :) and the directional light is really more like for use as a sunlight. So before i ramble forever... Spots are the way to go if you want a definate area that the light will be hitting outside the window. Point lights if you just need the windows to glow... It also helps if you actually put in a narrow box with a glass texture applied for a more realistic look :) Hope this isn't rubbish, and hope it helps... All the best, Kutter
wabe ( ) posted Thu, 19 June 2003 at 11:13 AM
I think it is the same as in reality. A light in every room. No trick, i think. Only trial and error. I have done something like that in one of my pictures.
SAMS3D ( ) posted Thu, 19 June 2003 at 11:35 AM
I agree with what was said above. I mostly use trial and error, if I really want to show light beams coming out of the window to shine on the outsite, I use spot lights, if I just want the lights in the window I use regular lights. Sharen
dolly ( ) posted Thu, 19 June 2003 at 11:41 AM
Yep as the above said,just think in turms of real life light this is just a box with 2 windows and a dividing wall in between the windows just add a light in eacg room and ya get this o you have to play with light settings to get desired effect but in principle it is very very easy hope it helps cheers dolly
sacada ( ) posted Thu, 19 June 2003 at 8:51 PM
If the buildings are background you can easily achieve this effect by using the lumninous effect within the material of the building. See the materials under 'Special Effects' like 'Building Lighing' and 'Building Lighting 2'. This method save hours of time placing and rendering lights without always needing to.
Diandra ( ) posted Fri, 20 June 2003 at 7:58 AM
Oh this is great. Thanks everyone. A big help and a great starting point for me! You guys are the best! :) Diane
