Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
OK, I figured it out. Set your figure and your prop how you want them posed. Set IK on for both arms. Select a hand, and go to menu/object/change parent and select your prop. Do the same with the other hand. When you move your prop, the hands and arms will follow. You must use caution, as it is easy to get major deformities in your figure if you move the prop too far.
Is there a way to make one or both hands lock to a prop that is in the hands like a sword or staff, so that when you move the PROP the hands will move with it? Kind of like IK?
