Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
i have to agree with double crash, a little tweaking on the ambience on the wood... and another one... a room especiallya living room or family room has always a window... your picture is in a corner.. it musty have at least one window... It not only gives more spice to your pic it will certainly kill of the drabiness.... well not unless this is a bunker then you have to really put walls and no windows... just a little thought
Thanks for the tip on the ambience. I didn't like the table texture either but didn't know which variable to adjust. One of these days I'll have to actually finish Susan Kitchen's book and learn about the material editor. I really have to thank the forum for this image. alvinylaya inspired this image and also pointed me to the rounded cube in Bryce 5's imported objects which enabled me to model the sofa and the table tops. ocddoug's tutorial on lighting and the forum's discussion on ranged falloff helped me with lighting this room. I used two radials with ranged falloff and soft shadows. Rochr is indirectly invovled. He posted a tutorial on 3dtotal.com which the forumites mentioned. This led me to a new site (to me) which had the wonderful cloth, brick, and wood floor textures in this image. Other details on the image ... Flowers made in Plant Studio. Vase and endtable legs made in Gigahedron's Oxygen. Everything else modeled in Bryce. Vase texture and mug texture are Bryce defaults. Table texture is by Jonathan Allen.
I agree with DC and I must say that it does sort of look a bit impersonal at the moment although I can't tell you what might make it a more livable environment. But a window might do the trick. Jason I wish you luck in reading the section about the materials editor 'cos it goes on forever and there is so much information to come to grips with. I've been reading that particular section for weeks now, I keep going back to bits again and again to get them right. Catlin
Jasonmit, here's my thoughts for what they're worth: the first thing I noticed was that the lighting. The center of the pict is not very well lit making a 'hole' in the center of the pict. The sides each being well lit compete for your attention. if the point of focus is the table, your lights should draw you to it, not away and towards the wall on th right. A window or a picture on the right might help, but only if the focus is there. My ex-wife, whom I seldom quote - partially becuuse most of what she said was incomprehensable to mortal men, always used to say "why do they call it free advice? 'cause it ain't worth nothin'" cheers, - TJ
I really have a personal hate against standard ambience settings, LOL, I really can't understand why they come so varied and confusing, so: I usually set the ambience to the same exact value for every object in the picture (if you shiftclick on the ambience color it will bring you up a color-picker and you can enter the RGB values manually), thus avoiding shadows of different colors. You will discover that not many presets are affected by this, they only look better. Your second example shows, more or less, that I'm right :) Ehm :) S.
I won't comment on the lighting, because so many people are already offering better help than I could. I would say that I think the table desperatly needs an open book on it. As though someone was just sitting there drinking a hot beverage and reading their favorite novel. Maybe a pillow on the couch for them to lean against? Lin, who has spent many an enjoyable hour drinking hot beverages and reading her favorite novels.
