Mon, Nov 25, 8:39 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: Newbie needs help with path
seaayre ( ) posted Sat, 21 June 2003 at 8:37 PM ยท edited Mon, 25 November 2024 at 6:48 AM
Hi. I am quite new to Vue, but having fun so far. :D I know there is lots wrong with the image, but my main problem right now is figuring out how to make a little path or walkway to the front steps of the cottage. I found a tutorial for a path, but it seemed quite advanced, and probably more complex than I need for this image. Any suggestions at all would be welcome. Thanks! :) --Karen
YL ( ) posted Sun, 22 June 2003 at 2:18 AM
Maybe go to terrain editor (double click on terrain), then select the dig brush, adjust the size, and try to do your little path. It will be a trial and error process, so you should save your initial work ;=)
gebe ( ) posted Sun, 22 June 2003 at 4:58 AM
If your ground is flat, you also can create a path in the terrain editor. Just open it, click RESET and draw your path. Clip it and OK. Guitta
seaayre ( ) posted Sun, 22 June 2003 at 11:48 AM
Thank you for the tips. I will give them a try. :D
