I've not seen that either, Sentinel. I don't have Yuma texture, but I have Yazoo/Yoda. I can give a try tomorrow and see if I can duplicate it (same artist made the textures). Beautiful eyes!
This ia a common occurance in Bryce with Mike. This happens when the Eyebrow objects intersects with the forehead. Vic and Steph don't have this problem because the natural position of both eyebrows does not intersect. What this looks like to me, is that there is a morph target forcing the eyebrow objects to intersect with the forehead and thus the interaction. If the character map uses the eyebrow objects, try either selecting and moving the eybrow objects SLIGHTLY away from the face or checking the face settings in Poser and reimporting. If the texture does not utilize the eyebrows, delete them. Hope this helps, Will
I tried to delete the upper eyebrow in Vue, but only found it in the material summary, not in the "body parts" of the imported pz3, so couldn't figure out how to delete it. I did see that on import, the bump on the upper eyebrows is at 1.0, and thought that might cause it, but when I reduced that to zero, the lines still showed up. I'll do a couple other characters this morning and see if the same thing happens; I've never noticed it before, but I don't do portrait-style closeups that much. I'd like to see your results; I'll post mine here.
Attached Link: http://www.fallencity.net/lore/vue-michael.php
Have a look at Crescent's tutorial and see the part about the eye lashes. GuittaThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
