Tue, Jan 28, 4:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Modeling Problem
Dragonsbld ( ) posted Sat, 28 June 2003 at 10:43 AM ยท edited Tue, 28 January 2025 at 4:36 PM
Since no one has brought it to my attention before i thought i'd ask wahts going on here. The Model looks ok in everyprogram i've loaded, even looks good when importing into poser.. but it removes a section of the model when i save it as a poser prop. someone explain this to me
maclean ( ) posted Sat, 28 June 2003 at 10:47 AM
'even looks good when importing into poser' Does it also look good when it's rendered in poser? It looks to me like a flipped normals problem. If it is, rendering should show it. I think you fix it by checking 'Make polygon normals consistent' on the import dialog. mac
Dragonsbld ( ) posted Sat, 28 June 2003 at 10:49 AM
That image is the rendered one, like i said, the imported model hasn't seemed to have a problem at all.. just when i turn it into a pp2, but i'll see what your suggestion does.
PhilC ( ) posted Sat, 28 June 2003 at 10:51 AM
  • Do you have all the service releases installed?
  • Is the polygon still missing when you render?
  • Is the rouge polygon more than four sided?
  • Was there an "R" in the month when you saved the prop? :)
Dragonsbld ( ) posted Sat, 28 June 2003 at 11:06 AM
more then four sided, that seems to be the problem.. take it poser doens't like those. oh well, guess i'll figure something out thanks for the help
