Wed, Feb 12, 11:53 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 12 7:20 pm)
Carrara Free Stuff here.
Subject: vertex shaping
3ddave44 ( ) posted Mon, 30 June 2003 at 8:37 PM · edited Wed, 01 January 2025 at 3:43 PM
Hi- I'm wanting to extrude or sweep a large circle to a smaller circle along a path as shown in this illustration: shapeStart.jpg When I select the objects as shown and set the vertex for the sweep (the yellow dot on the curve), instead of getting what I would think a horn shape like this, shape.jpg both circles get sweeped and I get this: shapeResult.jpg Shouldn't I be able to sweep the two circles and have the scaling follow from the big circle to small circle? I did the one that looks like what I want in the spline modeller but I'm stymied that my method in the vertex room is doing what I don't expect. What am I doing wrong? Thanks if anyone knows. Dave
nomuse ( ) posted Mon, 30 June 2003 at 10:25 PM
As far as I know the vertex room doesn't work that way. I've been doing things like extrude, scale, extrude, scale, extrude, scale for a controlled taper. Or you could make it in the spline modeller in first place then "convert to other modeller."
keithw ( ) posted Tue, 01 July 2003 at 12:30 AM
The easiest way to do what you want is to create a cone and deform it with the Bend & Twist deformer.
3ddave44 ( ) posted Wed, 02 July 2003 at 10:33 AM
Thanks folks for your answers
