Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
Best way is start poser and load a box from your propfile. Tnen go to Render>Materials>Load Bumpmap, and find/select the .jpg you want to convert, click open. A window will open, "Image files must be converted to BUMP", click YES. Do this before useing the figure/object and poser won't keep asking for the missing files, even stalling. A little trick I use, I don't use the bumpmaps till my final render. Bum takes a lot of space, very big when converted. You will be able to work on your scene without fear of crash. Save often so you don't lose all your hard work.
Ok, second best. My default window is blank too. The ground plane wins. I mostly open my Poser with Pz3's, that way I have all my lights and settings I'm working on. So I just use whatever I have in it to convert. Some of this stuff is habit now, sometimes I forget what it was like to do it for the first time.
I just got the texture pack for V3 and it says i need to convert the .jpg Bump maps to .bum files for the mat poses to work....How do I do this? Im using Poser4..thanks for any help.. ~Nancy~
