One thing you want to make sure of is that the mountain is "Solid." When you go into the terrain editor, you click the downward arrow at the upper right-hand corner of the editor to make sure "Solid" is checked. burgi also made a good point. Unless you group them, you'll have nasty primitives jutting out of nowhere.
ok, heres the problem, I need a hole, booleans are supposed to make holes....well, I set one object (A mountain in this case) as positive and the other (The hole I want int he mountain) As negative, but when I apply the textures and posistion them, I get this nasty looking square thing (The base of the negative objects' terrain) smack in the middle...
I need a nice clean hole in my mountain, how do I do it?
