Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 5:20 am)
What kind of props? Things like doors or more complicated stuff? It's not hard, if you know how to model, but the approach depends on WHAT you're making :o)
Ah :o) That is probably pretty easy to make. Make the nunchaku in a way so that you do not bend the chain, then divide the chain into smaller parts and make the handles and all the chain links each a group. Then get PhiBuilder (Look at the link at the right in the Webring Top 15, Roy's Poser MAX Tutorials) and use that to make a poser hierachy. That's more or less it. It may need some joint ajustment, which you can do inside Poser afterwards.
I've sent you an IM :o)
No big secret L Just easier to make long explanations and so on in danish ;o) I'm using Max 3.5 and a little bit of Lightwave :o)
hi does anybody know where i can find tuts to make prop objects in 3ds max 5 to use in poser 4?
