I'm under the impression that you can only delete things you have added, like morphs, from withing the Heirarchy Editor, but I ran into the same problem and used CR2 Editor (which is around here under another name, I think) and that did it. I'd try and stay away from manually editing the CR2, most of the time, it is something like 2000 pages long in most cases, life is too short!
Doohh!! You mean after I get a figure's morphs adjusted the way I want for a scene, I can dump all that extra weight, all within P4?! I've been lugging around all those extra, unused, MT's cause it was too time consuming to go into MorphManager, do the surgery, and bring the figure back into the scene. Doing this in the Heirarchy Editor sounds much faster & less trouble , or have I misunderstood. (Never really fooled around in it) I've sometimes been accused of taking the long way around. "How Nance drinks a Coke"
heyas; yeah, the heirarchy editor seems stubborn about deleting things it thinks are important. in fact, i have some magnet dials on some body parts that no longer have magnets, and it won't let me delete those. sheesh. in the cr2, find the body part's xrot dial, then look in... ummm, the xrot's channels. first, leave the limits at 0/0 so dragging the body part around doesn't accidentally twist it. then find hidden=0 and change it to hidden=1.
oh! one other thing; also look for 'force limits =0' and change that to a 1, for that parameter. (or for that body part, not sure where exactly it is.) then if people turn off limits, they still can't x-rotate your piece. um, just be really REALLY sure nobody would EVER want to rotate it, or you'll drive them nuts. ('course, if it's something silly, they'll already be nuts for wanting to do it, but... ;) )
OK guys, in creating a new figure, I need to delete an 'xRotate' dial. To do this I can set limits to zero, but I would rather eliminate the dial. To do this I am assuming I will need to edit the Cr2, am I right on that? s there any easy way to do this, any application that makes it easier? Thanks in advance. VID
