Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
Here's the URL http://www.eurus.dti.ne.jp/~masasi/PROGRAM/MTmirrorU.html It's Masa's program. His main page URL is http://www.eurus.dti.ne.jp/~masasi/index.html It is a brand new program, and there haven't been many reports of how it works. I don't know if it will work with Vicki or not. She seems to be "different" in many ways, and some "standard" tricks don't work with her.
Specifically what I'm now doing is... Starting with a Vicky fully loaded with MTs, I pose her left collar, setting parameter dials for breast size, droop, etc. until I have the effect I'm looking for (possibly a dozen settings). Now I note all the settings for the left collar, go to the right collar, and individually set each parameter dial the same as the corresponding dial for the left collar. My question is, is there an easier way of doing this? (it seems like the figure symmetry function should do this, but it won't) I'll download Masa's program and play with it I'll also see if I can find any way to do the copy and paste thing. Letcha know if I find a way... Otherwise, it'll have to continue being the "brute force" method. :) Buck
I will have to try that. One suggestion: after you have your collars formed just so, save as a new cr2, open it in MorphManager, select a collar and combine the morphs into one. (char)breasts. export it if you want it in your morph library, delete the constituent morphs, repeat for other side, save the cr2. When you open in Poser set dial to 1.0. I suggest not including any "gravity" morphs in the combined one or deleting same. As you use different poses you will need to adjust those. If the conformation looks good, share the combined morphs.
Does anyone know of an easier way to transfer MT settings from Left chest to right (or vice-versa) on Vicky other than twiddling the individual parameter dials? The figure symmetry menu item only seems to affect limbs. Buck
