Mon, Jan 27, 12:28 AM CST
Subject: Adjusting V3's Height
7SeAs ( ) posted Thu, 10 July 2003 at 11:13 AM · edited Mon, 27 January 2025 at 12:22 AM
How do I adjust V3's height? Thanks
lhiannan ( ) posted Thu, 10 July 2003 at 11:23 AM
What exactly do you need to do? You can make any Poser model smaller or larger by adjusting the scale dials... "Scale" itself will make it smaller/larger, "Y-Scale" will make it shorter/larger, but just as wide.
7SeAs ( ) posted Thu, 10 July 2003 at 1:59 PM
Ahhh yes... I forgot about that lol. I wanted to save the 'height' setting together with other dials as a pose so I can reuse them.
lesbentley ( ) posted Thu, 10 July 2003 at 5:10 PM
You can't just y scale the Body because... well see figure 1 above. You can get some presets by using Figure height from the Figure menu, but this changes the proportions as well as the height. Only other way is to scale each body part individually (ERC can be a big help here).
7SeAs ( ) posted Thu, 10 July 2003 at 9:06 PM
I haven't try it y-scale yet. But yesterday I was trying to find the parts where I could possible adjust height, like shorter legs, longer arms. But couldn't find them.
Grey_cat ( ) posted Thu, 10 July 2003 at 9:19 PM
Try StretchArms and StretchLegs found in the body section. here's Vicky with her legs longer using StretchLegs. a negative will shorten.
FyreSpiryt ( ) posted Fri, 11 July 2003 at 6:26 AM
Adjust overall size, or proportions? For overall size (for instance, if you have two characters with the same proportions, but one is 5'1" and one is 6'4"), then the Scale dial (overall scale, not ScaleX, ScaleY, or ScaleZ) in the body is the way to go. If you want to change proportions, the StretchArms and StretchLegs dials scale body parts.
7SeAs ( ) posted Fri, 11 July 2003 at 9:53 AM
Thanks!
