Mon, Jan 20, 12:53 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Poser 5 Walk Designer ---- Is it working ?
Himico ( ) posted Sat, 12 July 2003 at 7:08 PM · edited Mon, 20 January 2025 at 10:43 AM
I could not open Poser 5 Walk Designer. P5 freezes when I try to open it.
It is working with Poser4.
stewer ( ) posted Sat, 12 July 2003 at 7:10 PM
Does it fully freeze or just take very long? In some cases, the first launch of the walk designer can take minutes.
Himico ( ) posted Sat, 12 July 2003 at 8:44 PM
Thank you for the response.
I waited for 6 minutes. I was going to stop it. It appeared.
It appeared after 6 minutes.
It is amazing !
thgeisel ( ) posted Sun, 13 July 2003 at 1:35 AM
it only takes so long if you load it for the first time.
elgyfu ( ) posted Sun, 13 July 2003 at 4:33 AM
Ah, I have never got it to work either. I will try waiting it out. Perhaps I will leave it when I go to work. It is annoying coz the Poser 3 version was so clever.
Mazak ( ) posted Sun, 13 July 2003 at 4:41 AM
Attached Link: Mazak's Grafikwelt
The walk blends are compressed that caused the long loading time of walk designer in P5
A solution:
Make a backup of your runtime/pose/WalkDesigner folder.
Decompress the walk blends with a P5 Python Script. Run Python... browse for the Poser folder and find the script 'uncompressPoserFiles.py' Type in the path your pose/WalkDesigner folder. Check the 'Delete Original Files' option and Click OK.
Walk Designer should load much faster now.
Mazak
Google+ Bodo Nittel
nerd ( ) posted Sun, 13 July 2003 at 10:47 PM
Forum Moderator
Get the latest patch for P5 too. It will help stability and load times in Walk Designer. Nerd
