Sun, Feb 2, 5:04 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: Urgent Help needed
greedo ( ) posted Fri, 18 July 2003 at 8:34 AM · edited Sun, 02 February 2025 at 4:55 PM
Hi, I am putting together an animation (Poser 4) using Mike. I ned to animate him walking and I started off using the Wlak designer. I am going about this in the exact way as in the Book that came with Poser 4 (Page 234) and it mentions to assign a figure type to the character, so I go an look for the mike figure type, I believe this is a .cr file, The problem is that I cannot find it or more to the point I dont have any cr files on my machine, any help is much appreciated as this is under a major time constraint. Thanks a mill
melanie ( ) posted Fri, 18 July 2003 at 8:45 AM
Hmm, I wonder if you mean cr2? That's what all the figures in Poser are. The cr means it's a character file. Melanie
greedo ( ) posted Fri, 18 July 2003 at 8:57 AM
Sorry, yes I mean a cr2 file, but as you can see from the attached image I dont get the option to use one, it appears as if the folder is empty. When i look into the folder using exploring there is a .cr2 file there, any ideas, Thanks
PhilC ( ) posted Fri, 18 July 2003 at 8:57 AM
Short of any better suggestions I would load in the Michael.cr2 file.
PhilC ( ) posted Fri, 18 July 2003 at 9:02 AM
Its possible that your figure files have been compressed. Try this:-
  • Load Michael into the scene.
  • Go to Edit/General Preferences
  • Un-Select "Use file compression"
  • Save Michael back to the figure library with a new name.
  • Try the walk Designer thing again. You'll find your saved file waiting for you.
Hope this helps.
greedo ( ) posted Fri, 18 July 2003 at 9:06 AM
Here is a screen grab, showing that I have it installed and I am definately pointing the walk designer to the correct location, how come the walk designer looks for a .CR file and not a .cr2 file? I know that are the same but the prog seems to label them as different, thanks greedo
PhilC ( ) posted Fri, 18 July 2003 at 9:07 AM
OK we are both typing at once :)
Notwithstanding the above I see that your flie Open window has a drop down "Files of type" field. Just opened mine and I can see it lists out *.CR2 and *.CRZ (compressed) files. All you may need to do is select *.CR2 for you to be able to see your files.
greedo ( ) posted Fri, 18 July 2003 at 9:13 AM
I see what you mean but I dont have that option, the attached image shows what happens when i try to see the drop down list of available file tyes Hmmm???? I havent a clue as to why this is the case, thanks again,
PhilC ( ) posted Fri, 18 July 2003 at 9:21 AM
Attached Link: http://www.curiouslabs.com
Oh bummer looks like you are CR2'ed !!!!!!
My list has *CRZ, .CR2 and ALL as options. I see your's has "(.CR" . I wonder if this was an error that was addressed in a service release. Is your version up to date?
Patches available at www.curiouslabs.com
greedo ( ) posted Fri, 18 July 2003 at 9:39 AM
Thats the problem alright, didnt see anything on their site so i have emailed their support (2 day wait), not much good when this is urgent, anyone got any ideas, thanks PhilC for hte help
PhilC ( ) posted Fri, 18 July 2003 at 9:51 AM
Attached Link: http://www.curiouslabs.com/go/downloads
Here is a direct link to the patches.
One last thought, sometimes you can just type the file name into the file/open field if you know it. Or maybe we could sneak up on it this way. Go to Edit/Preferences and SELECT "use file compression". Now save a Michael figure back to the library. Now see if the file is visible in the file/open box.
brandonc ( ) posted Fri, 18 July 2003 at 10:00 AM
also in the box for the file name try doing . and hitting enter it might then let you see the other files
ockham ( ) posted Fri, 18 July 2003 at 10:28 AM
Another alternative is just don't bother to "assign a figure" to the Walk Designer. I've found that it works well enough with its default; requires a certain amount of tweaking in any case. Incidentally, it appears that your Windows system is forcing a 32-character limit on the strings in the file box, which is why you're not seeing the 2 in the CR2. I've never seen this before; could your system be set for some odd kind of compatibility?
My python page
My ShareCG freebies
greedo ( ) posted Fri, 18 July 2003 at 10:45 AM
I think that does it alright, just typing in the name, thanks man,
PhilC ( ) posted Fri, 18 July 2003 at 10:51 AM
Yeah !!!!
