Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Ive had this promlem. Instead of trying to click onto something else on the taskbar with the mouse do the following: Hold down the ALT key and hit TAB this will move you to the next open application or.. Press and hold the WINDOWS key and hit M this will minimise all the open windows and allow you to choose what to do next. This should allow Bryce to continue along its merry way. Stash ;o)
you don't have to deinstall it for christ's sake... listen, you just did a major upgrade on your puter. you can't expect all apps to work. so it's simple. just pop in the cd and reinstall it. nothing more, nothing less. you don't have to uninstall it first. all yoru stuff will still be there, just that your app will thank you. no more bugs. takes 30 secs to install Drac
And be sure to run the Bryce 5 upgrade. It fixes some metaball bugs and adds a couple things. Sorry, I don't have the link.
If you re-install bryce don't forget to back-up your textures, models, sky's etc you added to the default library. They will get lost if you re-install. (at least that's whaqt happened when I last did a re-install.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
Definitely save your mats to another directory...I ,like StarTrek engineers, believe in double redunacy in all my systems, I save to the user folder and also to another directory outside of Bryce altogether, then save to a RW CD as I add more to the mats...saved my ass a couple of times with hours worth of work on models, mats and textures...
Bryce Forum Coordinator....
Hello, I just upgraded to Win XP SP1 and more RAM. Now I installed my Bryce 5 again and tried my first render... it's a mess! I was used to let Bryce render my pics quietly in the background and fumble around with other things but now immediately when I touch the taskbar or try to minimze the window the render process stops. aaaaaargh Does anybody else have this problem? Any ideas? Thank you!
