Forum Moderators: Staff
If the title of the document window is off the screen, you will need to set Poser to the factory default settings: 1. Go to Edit>General Preferences... 2. Under Document Preference, select Launch to Factory State 3. Under Interface Preference, select Use Factory State 4. Select the Set Preferred State button 5. Select the OK button. I hope this helps, Ericroy
The window where the figure is, the one that you see in the middle of the page, is not where it use to be. I dl'd a few new objects and mats and the next thing I know is when I open poser it has the window with the figure at the left top corner of the screen and I can't figure out how to get it back to the middle of the screen, it is covering my camera and light buttons, also half of my rotating buttons....please help.....I have poser 4 with the pro pak..... :(
